Brake Bleeding
If you're doing by having someone pump the pedal, BE SURE not let the fluid get too low in the master cylinder; refill it often. If it gets too low you'll suck air into the line and have to start over. 3 people is best; one to work the pedal, one on the bleed screw at the wheel, and a third to to keep the master full. Be sure to run enough fluid through so you get clear fluid out the bleed line; I'd suggest buying 2 quarts (that's what it took me). The manual calls for DOT4 to be sure to get that, not the more common Dot3.
