Brake Bleeding
Old Apr 6, 2007 | 07:51 PM
cincyTT's Avatar
I'm make believe
Default RE: Brake Bleeding
if you get a brake bleeder kitwith a magnet you can do it by yourself, i did.
Old Apr 6, 2007 | 07:53 PM
Dana Reed's Avatar
If you're doing by having someone pump the pedal, BE SURE not let the fluid get too low in the master cylinder; refill it often. If it gets too low you'll suck air into the line and have to start over. 3 people is best; one to work the pedal, one on the bleed screw at the wheel, and a third to to keep the master full. Be sure to run enough fluid through so you get clear fluid out the bleed line; I'd suggest buying 2 quarts (that's what it took me). The manual calls for DOT4 to be sure to get that, not the more common Dot3.
twenty8red
Aug 9, 2023 05:34 AM
esrest
Jan 20, 2013 10:17 PM
makav3li
Apr 18, 2010 10:52 AM
410ThirtyValve
Feb 3, 2009 11:44 PM
Lsand
Aug 2, 2007 12:29 PM
