brake pad sensor
The sensors are embedded in the pads. They are just a wire loop that completes a circuit and hook into a connector at the caliper. When the pad wears down to a point, it wears through the wire and breaks the circuit.. then the light comes on. If you have the brake sensors on your car and use a non-wear sensor pad, you'll have to add a resistor to keep the light from coming on.
bobbyenglish61
Aug 27, 2013 07:55 AM
