brake pad sensor
Old Mar 7, 2007 | 10:02 PM
sheepcan's Avatar
Default brake pad sensor
does anybody know if the brake sensors are built in or on the brake pad?
Old Mar 7, 2007 | 11:05 PM
XCLR8TT's Avatar
Default RE: brake pad sensor
The sensors are embedded in the pads. They are just a wire loop that completes a circuit and hook into a connector at the caliper. When the pad wears down to a point, it wears through the wire and breaks the circuit.. then the light comes on. If you have the brake sensors on your car and use a non-wear sensor pad, you'll have to add a resistor to keep the light from coming on.
Old Mar 8, 2007 | 06:05 PM
225tt's Avatar
Cool, is there any specific years or models that the brake pad sensors came in or that they came with? I have a 02 Roadster 225 and I am pretty sure that I dont have them.
Old Mar 8, 2007 | 06:24 PM
XCLR8TT's Avatar
You would have to look. You should see a small harness on the back side of the caliper. I believe it is located on the passenger front wheel.
Old Mar 9, 2007 | 10:47 PM
achTTung's Avatar
Instead of a resistor, you can always reuse the remains of the old sensor, just twist the wires back together and and you're good to go.
bobbyenglish61
Aug 27, 2013 07:55 AM
kustomkory
May 6, 2012 10:28 AM
justinsrx7
Mar 28, 2012 09:16 AM
OWDI
Mar 18, 2005 01:51 PM
TheMudge
Feb 16, 2005 01:38 PM
