Clutch problem I think.. help
Old May 31, 2007 | 10:47 AM
beetee's Avatar
Default Clutch problem I think.. help
This morning when i drove my TT the gears did not seem to want to go in, very clunky, as if no clutch.
Parked in town for 3 hours, when i got to drive home could not get it in gear at all.
After panicking for a few minutes noticed the clutch pedal was low to the floor, lifter it up and hey presto gear box would connect, drove all way home OK.
I have a warranty with the garage, so if there is a problem will need it sorting, is the clutch a hydraulic one? any way of checking fluids? is it linked to brake system?
Would appreciate any advice as have not got a clue on mechanics of a car, other than real basics.
[sm=bounceybounce.gif]
Old May 31, 2007 | 11:01 AM
diehlryan's Avatar
Default RE: Clutch problem I think.. help
sounds like slave cylinder is on the way out? anyone else agree? maybe needs to bleed clutch.. has it been changed recently?
Old May 31, 2007 | 02:26 PM
moeron7's Avatar
Try topping of your brake fluid. Its been working for me for 6 months. But ultimately yes I believe it is the slave cylinder.
Old May 31, 2007 | 03:06 PM
diehlryan's Avatar
ORIGINAL: moeron7
do you have to top the fluid regularly?
if so its leaking from somewhere and
if it looks like a duck, walks like a duck, sounds like a duck ... its most likely your slave cylinder.
Old May 31, 2007 | 03:46 PM
moeron7's Avatar
ORIGINAL: diehlryan
I like blue ducks. But I only have to top it off like once a month maybe, so its a slooooooow leak.
Old May 31, 2007 | 03:56 PM
qwert's Avatar
hate to tell you this but the same happened to me and i needed a new clutch it sucked
Old May 31, 2007 | 04:40 PM
beetee's Avatar
Thank you so much for your thoughts, I will be taking car back to dealer with print off of your comments !
looks like new clutch !!
What a helpful forum, only just joined today and already been helped so much !!
Old May 31, 2007 | 04:59 PM
225tt's Avatar
Helpfull???
Old Jun 1, 2007 | 04:28 AM
beetee's Avatar
It is helpful for me as I know only basics.. when car wouldnt go in gear, called my partner, when he gets there he sits in for one minute, pulls the clutch up and then it works. ! left to me it would be RAC recovery truck and mild panic, so at least getting some answers on here I can talk some sense to him !!
Hopefully garage will be helpful and compete work under warranty, or no doubt that will be another battle !!
Old Jun 1, 2007 | 06:18 AM
diehlryan's Avatar
clutch is a wear item and is rarely replaced under warranty -- good luck to you though.
jdwallace1970
Aug 10, 2013 02:39 PM
ikkezelf
Jan 31, 2008 06:54 AM
Matt_Iliketurbopull
May 1, 2007 05:28 PM
Matt_Iliketurbopull
Apr 28, 2007 03:06 PM
dane
Mar 3, 2005 07:25 PM
