Coolant light
Old Jan 8, 2009 | 05:13 PM
Tadyswoows's Avatar
Default Coolant light
When i first start my car during cold mornings my coolant light comes on i checked the level and it is full. Does anyone have any ideas why this is happening? Thanks guys
Old Jan 9, 2009 | 12:12 PM
cincyTT's Avatar
I'm make believe
could just be another wonderful cold electrical issues these vag cars seem to have.
Old Jan 9, 2009 | 02:18 PM
jhsoccerodp's Avatar
sensor could be on its way out, who knows like cincy said these vag cars, actually german cars in general and the electrical problems.
Old Jan 9, 2009 | 05:49 PM
Wintermute's Avatar
Sensor is bad. Doens't take that long. I had same problem. Make sure if you buy it the OEM green top.
Old Jan 9, 2009 | 06:08 PM
ninjatturtle's Avatar
Member
mine started doing the same thing when the battery started to fail. stayed on a few minutes and then went off. thought the new battery would fix it but it still happens on cold mornings. i noticed the level is a little low until the car warms up then the volume increases. check the level before you start your car while its still cold and see if its under the min. level.
Old Jan 10, 2009 | 02:21 AM
Murderface's Avatar
Mine's done it for a long time, I think the coolant just shrinks up a bit when it's cold and puts it below the level of the sensor...in a minute once it warms up a little it turns off.
Old Jan 10, 2009 | 09:44 AM
XCLR8TT's Avatar
It's actually the sensor inside the coolant expansion tank... that round one on the passenger side. There is a sensor in there that checks the level. You can either change out the tank for a new one, or try to clear the sensor. Try taping some sandpaper on the end of a screwdriver and reach in to clean off the sensors.
Old Jan 10, 2009 | 12:09 PM
achTTung's Avatar
I'll go with the coolant expansion (or more like contraction) theory.
How cold is it when you have this problem? Happens to me anytime its below 15°F. Like last night, when it was -4°F.
On a cold day, check the level before you start the car. I bet you'll see its below teh sensor. Doesn't take long to warm up and fill the bottle again.
Old Jan 10, 2009 | 03:13 PM
Murderface's Avatar
Same here, it's only when it's somewhere below freezing. I usually check the level quickly just in case.
Old Jan 11, 2009 | 11:47 AM
ouTTie914's Avatar
+1 Happens to me all the time during the Winter.
Mossyoakglock
Dec 28, 2010 01:13 PM
shady927
Mar 2, 2009 12:23 AM
Ph3N0m
Oct 21, 2008 12:58 PM
Shwabmyknob
Nov 25, 2007 10:07 PM
