engine light flashes when accelerating-car stutters
Old Jul 3, 2008 | 01:32 PM
techbod's Avatar
Default RE: engine light flashes when accelerating-car stutters
NGK PFR6Q GAP 0.8MM
BOSCH 4 FR78 GAP SET
CHAMPION RC8PYP GAP SET
iridium plugs should never be regapped because it weakens the the gap-per/or rod on the plug that you bend to re-gap and they break off and you want to see the damage they do to the cylinder head[:-]
Old Sep 8, 2008 | 08:24 PM
greg808's Avatar
I have similar issues. The car would hesitate every once in a while. Yesterday, it did it more and the check engine light would flicker. Then it flashed and stayed on. The car is a 2002 225 with the REVO flash. It has 80k and the plugs were changed at 74K. The coil packs are the originals. I will get the CEL code tomorrow, but do you concur that it is most likely the coil packs?
Old Sep 8, 2008 | 08:43 PM
greg808's Avatar
One more note, it only hesitated in high-load, high-boost situations. Regular driving was not an issue.
Old Sep 8, 2008 | 09:24 PM
achTTung's Avatar
had exactly that happen a year ago at H2O. Bad plugs.
I had ordered new plugs, but they didn't come in before I left for the show. One plug probably had nearly a .040" gap due to erosion.
Change your plugs first, an BTW, I'd almost say any iridium plug is at least some hype. That hype is the 50-60K service interval they claim. You could probably get 30K out of a regular copper core plug at a 1/4 the price. Even changing the plugs twice as often, you're still coming out at half the cost.
Old Sep 9, 2008 | 12:36 AM
Mobius97's Avatar
This sounds like plugs gapped incorrectly as well, are they set at .028 (this is gap for chipped car)?
If the trouble still persists... find what cylinder you are misfiring in, swap that CP with another and see if the trouble follows the pack.
I would first start with a known good set of plugs that are gapped correctly.
judgejules95
Nov 29, 2012 12:18 PM
davetec
Oct 29, 2007 05:23 PM
huyaroo
Sep 12, 2007 03:37 PM
