Guys with boost gauges
Old Jun 21, 2007 | 12:06 PM
225tt's Avatar
Default Guys with boost gauges
Hey just wondering how much vaccum do you guys run at idle, or does anyone know what your supposed to run. I noticed on a pic of my gauge that I am only get about 14 on the boost gauge. Just wondering if this is the norm or not. Thanks.
Old Jun 21, 2007 | 12:34 PM
zachaTTack's Avatar
Default RE: Guys with boost gauges
i seem to run about 18 to 20
Old Jun 21, 2007 | 12:36 PM
zachaTTack's Avatar
scratch that 18 to 20 at start up and deceleration but like 15 or so at idle i just checked
Old Jun 21, 2007 | 01:00 PM
diehlryan's Avatar
i think 20 is the norm.
Old Jun 21, 2007 | 02:14 PM
cincyTT's Avatar
I'm make believe
with 2nd air pump on it should be ~15in hg and when warm or crusing ~20in hg (depending on altitude).
Old Jun 21, 2007 | 02:20 PM
chosos's Avatar
i have a 180TTQC
19 vacuum.
11 Boost
My DP is broken and I "think" i have a pinhole vacuum leaksomewhere around my SMIC because I was throwing a code(17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!) P1297)but maybe it could be that my broken flex pipe (totally disconnected at the flex pipe...). The problem has to be killing my backpressure.
Old Jun 21, 2007 | 02:32 PM
225tt's Avatar
So if I am only seeing 14 what is wrong? That is after SAI is off everyting is warmed up and just idle...
Old Jun 21, 2007 | 04:30 PM
MeanAudiA6's Avatar
i'll double check but i'm pretty sure mine is around 20-25 hg vaccum after warm up....like i said i'll double check. just go ahead an order the starter kit form Hose techniques.com and replace every hose....i did and its really easy...only hard ones are the two on the intake manifold(that you will have to take off to get to)
whtturboa4
Jun 4, 2010 07:17 PM
jojoenglish85
Nov 25, 2007 03:55 PM
2003silvervette
Jun 27, 2006 03:08 PM
Audi son
Mar 15, 2006 01:49 AM
Skibos
Apr 15, 2005 03:47 PM
