NEED NEW CLUTCH
I HAVE A TT Q 180 HP 5 SPEED. I NEED TO GET A CLUTCH FOR THIS THING; I WOULD LIKE TO GET A BETTER CLUTCH THAN STOCK. I CANT SEEM TO FIND ANY CLUTCHES OTHER THAN OEM FOR THE 180 HP QUATTRO; ANY HELP WOULD BE GREAT.
=JERED
[/align]
ECSTUNING.COM
A WORD OF ADVICE DON"T TYPE IN ALL CAPS AND TRY USING PUNCTUATION BECAUSE PEOPLE HERE WILL FLAME YOU FOR IT AND CALL YOU A NOOB.
Seriously, use the standard font.
Ecstuning has a wide range of clutches, a lot of people here have an ECS here.
Go with clutchnet. http://forums.vwvortex.com/zerothread?id=3510801
If you tell them you are on vwvortex, they give you 25% off
ORIGINAL: cincyTT
i havent seen only one person complain about a clutchnet. That person had a 4 puck that wore out fast. But other than that, people have used the race pp with a full kevlar disc making over 450whp/tq. What i have seen to many times is spec clutches eating themselves so i wouldnt ever use their 228mm kits. [:'(]
Im basically down to clutchnet and competition clutch, more so the comp clutch from kineticmotorsport
good luck, ive seen several fail and not match up to the flywheel machining out of the box. i even a had a personal failure. 228 mm kits have held much more power than 240's on this scene.
ivanruiz817
Sep 16, 2011 02:38 AM
loves4
Feb 12, 2008 08:45 AM
Matt_Iliketurbopull
May 1, 2007 05:28 PM
Matt_Iliketurbopull
Apr 28, 2007 03:06 PM
