New Audi (This can't be normal)
Old Jun 3, 2008 | 04:10 PM
Warhawk's Avatar
Default New Audi (This can't be normal)
So like i mentioned in my post, i got a new audi, drove it 1/2 way across the country last night. It seems the radio does some funky stuff. First thing is, is when i shut off the car and remove the keys/open the doors, the radio stays on, i have to press the **** in to shut it off. Second, when driving after an hour or 2, it will randomly shut off and i have to press the volume **** in (to the off possition) then turn it back on, and it comes up just fine. Thoughts?
Old Jun 3, 2008 | 05:16 PM
achTTung's Avatar
Default RE: New Audi (This can't be normal)
thats weird.
The radio has a built in function to let it play for 1 hr with the car off/key removed, then it shuts itself off. Shouldn't do that while the car is running though.
It SHOULD shut off when the car is turned off. My parents Passat does that too though, you have to manually turn the radio off or it keeps playing. I don't know if it shuts itself off while they're driving though.
Almost like it's thinking in reverse. Plays when off, times out when on. Dunno how you'd fix that. Maybe the dealer has some insight.
Old Jun 3, 2008 | 05:40 PM
Warhawk's Avatar
Think disconnecting the battery cables would reset this? Could that cause any other problems with the ecu or anything?
Old Jun 3, 2008 | 05:44 PM
scoTT la rock's Avatar
ORIGINAL: Warhawk
make sure you have the radio code before you do this brother.....
Old Jun 3, 2008 | 06:02 PM
achTTung's Avatar
Doubt he'd have a problem with the radio code, but it doesn't hurt to make sure you do have it in case it does go into safe mode.
With all the work I've been doing to the electrical system on my car lately, I've had the battery disconnected for hours. I don't go into safe mode, and I don't lose my presets. It always comes back with the radio station in preset 1 selected, but nothing worse.
Early year cars went into safe like crazy, 01-02 and on (my guess), you'd need to physically try to remove the radio for it to lock.
Old Jun 3, 2008 | 06:19 PM
Warhawk's Avatar
do you think it would be worth a shot? i couldnt possibly make my ecu start throwing a code by doing this could i? its something i could live with haha
Old Jun 3, 2008 | 07:02 PM
Murderface's Avatar
My 2000 bose 6-disc unit has never gone into safe.
Old Jun 3, 2008 | 08:45 PM
achTTung's Avatar
Disconnecting the battery is the low cost (aka, free) way to clear codes. You shouldn't get codes from it. Give it a shot, but I dont think the coding for the radio is volatile, it'll probably retain all its info, including its quirks. But try it, I've been known to be wrong, and these cars have been known to be wacky.
4te
Apr 30, 2014 03:27 PM
alex.flores67
Nov 25, 2013 12:49 PM
Jorg
Sep 7, 2010 11:57 AM
suky321
Jun 6, 2010 10:07 PM
swarwi
Nov 20, 2007 10:16 PM
