Octane
Having searched the Forum, I found lots of discussion on octane ratings for chipped cars.
Mine is not chipped, and I read in the manual that Ethanol at 89 Octane can be used.
Save 20 cents a gallon if I do this, but curious what you folks think....?
And where does the chip go exactly? Do you just plug it in and go? Do you have to mess around hooking up a computer?
I was planning on buying the chip for the 225 hp model (01) from this website;
http://www.goapr.com/Audi/products/ecu_upgrade_tt.html
do you recommend it?
Chip local unless you plan on going with a larger turbo then get a chip from a tuner with a good BT program (ie: Uni). Stock turbo chips will all be close in performance.
The chip is either flashed on soldered into the ecu depending on year and # of programs
