Octane
Old Jun 20, 2008 | 10:37 AM
kwaskow's Avatar
Default Octane
Having searched the Forum, I found lots of discussion on octane ratings for chipped cars.
Mine is not chipped, and I read in the manual that Ethanol at 89 Octane can be used.
Save 20 cents a gallon if I do this, but curious what you folks think....?
Old Jun 20, 2008 | 11:02 AM
cincyTT's Avatar
I'm make believe
Default RE: Octane
Timing is pulled and you get lower mpg, so in the end you will be paying the same in the end filling with either but you will have more power with 93.
Old Jun 20, 2008 | 12:18 PM
kwaskow's Avatar
Default RE: Octane
figured as much - thanks for the explanation
Old Jun 20, 2008 | 01:38 PM
NeXeA500's Avatar
Default RE: Octane
The chip actually improves fuel economy. I gained about 3 - 5 mpg out on mine. I highly recommend it, as will everyone else.
Old Jun 20, 2008 | 02:28 PM
kwaskow's Avatar
Default RE: Octane
So I know this topic is covered twelve ways to Sunday......
What chip do you recommend and, what else is needed withsaid chip?
Old Jun 20, 2008 | 03:30 PM
dpatt420's Avatar
Default RE: Octane
And where does the chip go exactly? Do you just plug it in and go? Do you have to mess around hooking up a computer?
I was planning on buying the chip for the 225 hp model (01) from this website;
http://www.goapr.com/Audi/products/ecu_upgrade_tt.html
do you recommend it?
Old Jun 20, 2008 | 03:42 PM
cincyTT's Avatar
I'm make believe
Default RE: Octane
Chip local unless you plan on going with a larger turbo then get a chip from a tuner with a good BT program (ie: Uni). Stock turbo chips will all be close in performance.
The chip is either flashed on soldered into the ecu depending on year and # of programs
2000a4quattro
Mar 2, 2014 04:17 PM
beata4
Feb 4, 2008 11:45 PM
Pablo_Ottawa
Jan 25, 2008 09:48 PM
smokeU
Jul 5, 2007 01:14 PM
m5racer
Jul 28, 2006 02:12 PM
