Problem with A/C and Electric Fans
Old Feb 14, 2010 | 10:41 AM
carhopper's Avatar
Default Problem with A/C and Electric Fans
The other day I was stopped at a drive through and my temp climbed up from the middle to about 3/4. I quickly turned on my heat full blast in the car to bring it back down until I got on the road.
When I got home, I let the car idle for a good 10 minutes and it didn't overheat. It was about 32 degrees outside so the cooling system is very efficient right now. I did notice that during that 10 minutes the electric fans never turned on, but maybe they didn't need to. I then tried to engage the A/C and the clutch wouldn't engage.
Could the fan controller keep the A/C from engaging if the Control Unit doesn't see that they are turning on? I'm not sure where to start here, but that seems to be a good place. Any help would be appreciated. Thanks.
Old Feb 14, 2010 | 12:07 PM
carhopper's Avatar
I found the problem/s. The driver side electric fan is siezed so that's a no brainer. The AC must be heating up and now allowing engagement. When I cold started the car, the AC and secondary fan came on.
One note, I was checking fuses and noticed that most of them were severely tarnished. I removed all of them and sanded the contacts to a bright finish. This may have fixed the AC problem too, I'm not sure.
Any good sources for the fan other than the dealer?
Old Feb 14, 2010 | 12:25 PM
carhopper's Avatar
I found this one http://cpwstore.carpartswholesale.co...t=radiator+fan
Anybody know if the 225 and Base 1.8T have the same fan shroud?
Old Feb 14, 2010 | 09:24 PM
Soblu2ktt's Avatar
According to my manual the A/C will not engage when the outside temp is low. Not sure if that helps but just so you aren't spinning your wheels.
Old Feb 15, 2010 | 09:01 AM
carhopper's Avatar
That is good info, thanks. My fan is siezed and I found one on partsgeek that says it works on my AMU engine code "T VIN" for $114. We'll see.
Old Feb 17, 2010 | 09:39 AM
carhopper's Avatar
Fit perfectly, exact match with OEM.
ed1404
Nov 15, 2011 09:06 PM
popone913
Oct 10, 2009 01:26 AM
crashbahl
Aug 31, 2009 01:47 PM
Audicabrio
Jun 2, 2008 06:49 PM
NLT1.8T
Jun 5, 2005 11:10 AM
