replacing ECU
Very last letter(s). All ecus can be swapped with the same engine code. If the numbers dont match, you either need a immo defeat and/or code from the org ecu. You can get more info from ross-tech.com.
Just as long as its from a ATC fwd you shouldnt have a problem.
Read these
immo2http://www.ross-tech.com/vag-com/cars/immobilizer2.html
immo3http://www.ross-tech.com/vag-com/car...-swapping.html
You should have a immo2
Read these
