replacing N75 w/ mbc
Old Dec 22, 2007 | 07:35 PM
zero388's Avatar
Default replacing N75 w/ mbc
if the N75 is what I think it is(i might be wrong) from what I understand it is the thing ontop of the intake pipe right next to th DV. If this is correct then when I put in the mbc what do I do with the plug that goes into the N75?
Old Dec 22, 2007 | 08:02 PM
eliTTe's Avatar
Default RE: replacing N75 w/ mbc
look on cincy's profile at his pics, that will answer all your ?'s
Old Dec 22, 2007 | 11:53 PM
cincyTT's Avatar
I'm make believe
Lucas means this pic. That is your N75 btw. Just remove the lines going into the N75 and install them on the mbc. You can then leave the N75 in the intake and you need to plug it in electronically. Should look like this when done. Also you can plug the lines to the N75 if you wish, leave them open (mine are still open [:@]) or take a vac line and run it to connect the both to block off the lines.
Old Dec 23, 2007 | 12:09 AM
zero388's Avatar
ok thanks guys. Cincy i'm getting the same mbc that you have and I am very excited.
Old Dec 23, 2007 | 12:17 AM
cincyTT's Avatar
I'm make believe
Its really nice, just take your time to set it up properly. The directions are really strait forward but if you need any help, just shoot me a pm
Piperalpha
Aug 5, 2011 02:43 PM
Tmoney
Aug 4, 2008 09:48 PM
Audi858
Mar 6, 2008 06:21 PM
thebar
Dec 22, 2007 05:00 PM
skidplatexa4
Apr 14, 2005 01:42 AM
