replacing N75 w/ mbc
if the N75 is what I think it is(i might be wrong) from what I understand it is the thing ontop of the intake pipe right next to th DV. If this is correct then when I put in the mbc what do I do with the plug that goes into the N75?
Lucas means this pic. That is your N75 btw. Just remove the lines going into the N75 and install them on the mbc. You can then leave the N75 in the intake and you need to plug it in electronically. Should look like this when done. Also you can plug the lines to the N75 if you wish, leave them open (mine are still open [:@]) or take a vac line and run it to connect the both to block off the lines.
audi, garett, guide, install, instructions, kinetic, location, mbc, motorsport, n75, picture, replace, replacen75withmbc, t3, tt
