Some more electrical issues to the list it seems.
For the past few months i have had several electrical issues that have popped up one at a time and Im wondering if there may be an underlying issue that I should check into. It started with my headlight going dim then to shutting off completely which led to premature bulb failure. I replaced the bulb and ignitor thinking ok np but it hasnt fixed that issue. Then my instrument cluster went on the fritz starting with the gas gauge then the speedo dropped 35mph to below 0 at idle. Now my fuse for the the instrument cluster is beginning to blow constatly. Like I said the three main things are being taken care of but I want to make sure there isnt something I should check out before I dump 1500 into it to have the issue start again. The fuse issue is a huge concern right now as I live in New England and snow is inevitable and great tires only go so far....I miss my traction control. Any help would be greatly appreciated. The car just hit 200k a few months ago an I'm not ready to give it up just yet.
Thanks
Thanks
