Suspension Problem, Need Help ASAP
Old May 24, 2008 | 01:02 PM
diehlryan's Avatar
Default Suspension Problem, Need Help ASAP
We are having trouble getting the front drivers side strut out of the mount, the control arm doesn't drop down far enough to pull the strut clear of the mount. Everything is loose, tried compressing the spring but no go- Any suggestions? We need about a half inch more room to get it up and out- really frustrating!
Old May 24, 2008 | 01:26 PM
.clipse's Avatar
SoCal Crew Member
Default RE: Suspension Problem, Need Help ASAP
^ i took out the spindle for the fronts.
Old May 24, 2008 | 01:54 PM
cdTT's Avatar
The Bentley manual says to unbolt the driveshaft from the transmission flange. Hopefully that will give the room necessary to remove the strut.
Old May 24, 2008 | 02:02 PM
cincyTT's Avatar
I'm make believe
Hope you are using this How-T0, should make your life much easier
http://www.nclh.org/car/coilover_howto/
Old May 24, 2008 | 03:35 PM
.clipse's Avatar
SoCal Crew Member
ya if ur ever doing coils, i'd lithium grease the threading, perches and the plate in between the top and lower springs
Old May 24, 2008 | 04:05 PM
diehlryan's Avatar
We finally got it by standing on the rotor- and by calling rayveedub for advice, <<<<<thanks man! 3 corners down and one to go-
Old May 24, 2008 | 06:12 PM
diehlryan's Avatar
Thanks Collin for the help today. We couldn't get the last corner (passenger side.) The spring compressors I have are just a little to bulky to get up in the strut tower the right way to be 100% effective.
I know I can get around this with unbolting the axle from the tranny. Is this something someone of my skill level can do? Is it as simple as undoing the 6 or 8 bolts I see at the tranny/axle union and then bolting back up when done?
Any advice is appreciated.
Ray if you want to bring some of your tools down tomorrow or Monday and finish up that would be great.
Old May 24, 2008 | 06:27 PM
tt yo's Avatar
you could unbolt the axel from the front by the rotor and just get a pry bar and pry on the arm
Old May 24, 2008 | 09:29 PM
.clipse's Avatar
SoCal Crew Member
^ i did the same. it was a b!tch to get out the rotor from the axel. i remember after i was done and i redid all the brake lines i had no brakes for a good second that scared the **** outta me
pump those brakes!
mugenxv
Mar 20, 2012 01:49 PM
mugenxv
Mar 20, 2012 04:34 AM
patrixx006
Jan 20, 2012 12:00 AM
hearmespool
May 21, 2011 06:20 PM
ryanylva
Sep 30, 2008 09:19 PM
