Version 2.0.......T (Engine at shop!!!)
Old Sep 5, 2007 | 07:51 PM
  #41
ooantipostoo's Avatar
Default RE: Version 2.0.......T
Thats why you have the controller like the snowperformance that adds with gas.....
Old Sep 5, 2007 | 07:54 PM
  #42
cincyTT's Avatar
I'm make believe
Safest -> Dangerous
Direct port = adds nitrous and gas equal in all cylinders (my way) -> wet shot = adds gas-> dry shot = no gas(your way)
Old Sep 5, 2007 | 07:55 PM
  #43
ORIGINAL: cincyTT
Safest -> Dangerous
Im running wet. With no problem what so ever. It has been in for over 2 months now.
Old Sep 5, 2007 | 07:59 PM
  #44
cincyTT's Avatar
I'm make believe
brand, shot amount, where injected?
** stock fuel pump and diode?
Old Sep 5, 2007 | 11:31 PM
  #45
proxeyed's Avatar
Hey cincy, just curious if the 1.8 could go even higher than 2.0, such as a 2.2 or 2.5? I realize more work and more $$, but what are advantages/disadvantages of uping the displacement higher than a 2.0t? Thanks for all your input buddy, you"ve been a big help.
Old Sep 6, 2007 | 02:29 AM
  #46
brand nitrous express, shot amount 100, where injected intake?
** stock fuel pump wall 255and diode is in swap 4.3 with 4.7 whenshooting.boost still cuts at wide open throttle looking around for a fullyprogramable ECU program.
Old Sep 6, 2007 | 10:26 AM
  #47
cincyTT's Avatar
I'm make believe
dont swap diodes and you really need to limit the amount of boost with a wet shot on stock internals. If not, you may be walking home.
Old Sep 6, 2007 | 10:34 AM
  #48
cincyTT's Avatar
I'm make believe
ORIGINAL: proxeyed
If you use a tdi crank and block you can get to 2.1L and with a eurospec crank, you can get to 2.2L, i think you need a tdi block for that also. If not you have to modify your stock block a certian way i believe.
Here is a 2.2L build
Just keep in mind that a 2.0 wont really change your stroke and still allow you to rev to 8k with head work and the larger stroker wont. Plus i have OEM parts or direct replacements.
Old Sep 6, 2007 | 02:12 PM
  #49
cincyTT's Avatar
I'm make believe
Pistons and rods are here, will post pics soon enough
Old Sep 6, 2007 | 03:24 PM
  #50
cincyTT's Avatar
I'm make believe
Ordered Mon/Tues and recived today.
Big props to Arnold @ pagparts for the custom pistons and Bob Q @ qedpower.com for the rods. Crank, TB, and headgasket kits will be here tomarrow most likely
