Washer Fluid Reservoir
Old Mar 20, 2010 | 10:53 AM
beachchair's Avatar
Default Washer Fluid Reservoir
I am having an annoying problem with a leak somewhere in my wiper fluid line. Filling the reservoir only lasts a short time (overnight) until the tank is empty, and the warning light comes on again. There are no obvious signs of a leak that I can see. Ideas?
Old Mar 23, 2010 | 02:50 PM
LeVitre's Avatar
I had this same problem. I thought it was the tank so i replaced that, that did not take care of it. So i replaced the pump that pushes fluid to the headlamp sprayers and that did it.
Hope this helps.
Old Mar 24, 2010 | 07:35 AM
beachchair's Avatar
That's a thought.
I've removed the fender well to access the tank and traced all the lines and found no leak, so the pump is one of the few options left.
Thanks. It's always something with this car.
Old Mar 24, 2010 | 10:14 AM
LeVitre's Avatar
I know how you feel.
The best way to test the pump is to fill your tank, turn your headlamps ON and run the washer then just watch. Mine had a nice steady stream of fluid.
cheesy44
Sep 4, 2013 08:31 AM
Mach Schnell
Mar 11, 2010 09:50 AM
zzr
Nov 17, 2009 08:38 AM
00S4tt
Oct 8, 2008 06:14 PM
elude
Apr 24, 2006 06:26 PM
