WET Passenger floor!!!!
Old May 16, 2017 | 08:35 PM
Rudy's 01 TT Quattro's Avatar
Originally Posted by spikkeman
check the battery pan on the firewall there is a drain hole there if it gets clogged water will come inside the car flooding the passenger side floor and that is where your transmission computer, that is not a good thing
"Check the battery pan on the firewall". Hmmmm.
Other than a 2000 VW Passat, I'm not sure which vehicle you are referring to. The MK1 Audi TT convertible battery is in the "Front" of the engine compartment, not at the rear of the engine compartment where the firewall is located.
Old May 16, 2017 | 08:44 PM
In response to the "Original thread". it sounds like it could be your heater core. The heater core (with the exception of a right hand drive), is located on the passenger side, behind the glove box, attached to the firewall. It's not uncommon for these to go bad.
Old Feb 20, 2018 | 02:51 PM
Ad0911's Avatar
Did you ever locate the drain holes? I have a wet spot just beneath the pedals of my lhd roadster. Never been able to find the source. But I know I can smell the antifreeze of the waterjets in the wet spot
asrod2007
Audi Q7
Oct 10, 2014 12:32 AM
akricer
Aug 20, 2011 03:25 AM
kevin1533
Aug 18, 2008 01:18 AM
jaimea6
May 15, 2008 10:30 AM
StephenSaved
Jun 12, 2006 12:50 PM
