'00 a4 won't start...please help!
Old Feb 3, 2008 | 06:49 PM
JCatt9's Avatar
Default '00 a4 won't start...please help!
Hi guys,
So here is the story over the last few weeks when I started my car it would slightly hesitate before starting maybe due to the fact I live in canada and it's been really cold here, but to make a long story short after driving my car home from work and letting it sit a few hours it will no longer start at all. The battery isn't dead I can still watch my indash dvd and the interior lights are bright, but when I turn the key all i get is a slight tick and nothing. I tried jumping the car nothing, I plug in my engine code reader and all I get is error butno codes which is strange as it's never done that before.....Any idea what it could be guys?, I'm thinkig starter but i'd like to see if i can trouble shoot it any further before I tow it to the shop. Also I just had my indash dvd installed 2 days ago, but that shouldn't matter should it?
Thanks in advance, JC
Old Feb 3, 2008 | 07:43 PM
CLX's Avatar
CLX
Zombie Defense Force
Default RE: '00 a4 won't start...please help!
Probably the starter solenoid.
Old Feb 3, 2008 | 10:42 PM
JCatt9's Avatar
anyone else?, I've searched this issue but can't find much. Also would the immobilzer light come on if that was faulty?
Old Feb 4, 2008 | 05:21 PM
JCatt9's Avatar
bump
Old Feb 5, 2008 | 10:51 PM
dankhound's Avatar
If it were imobilizer the car would start but then die. Do the lights dim when you try to start the car. If they do, then you have a starter issue. If they dont, you need to check the small wire at thestarter for voltage. If you dont have 12 volts then you have a starter circuit malefunction ie ignition switch, clutch pedal switch or park neutral switch, or a wiring problem. If you have 12 volts, you have a starter, starter cable or ground issue.
Chito
Jun 28, 2010 08:48 PM
mark944turbo
Oct 10, 2005 05:51 PM
