2001 A4 ABS Module help!!!
Old Mar 11, 2014 | 06:47 PM
sf_brian's Avatar
Default 2001 A4 ABS Module help!!!
So my ABS light is on and the brake light on the cluster is blinking. The shop I went to said its due to a bad module causing my ABS to engage and causes my brake pads to prematurely to wear unevenly. They quoted me $900 for the whole thing. Is that a fair price???
Old Mar 11, 2014 | 08:00 PM
soulstep's Avatar
Read my post in your other thread.
Old Mar 11, 2014 | 08:39 PM
Mad Cow's Avatar
$900 is insane, probably based on the price of a brand new unit which is completely unnecessary. There are people/companies that rebuild these things for $100-$150, just google abs unit rebuild.
Old Mar 11, 2014 | 10:34 PM
hartsoe1's Avatar
there is a reset procedure using the paid ($99) version of VCDS lite, which involves steering wheel position and entering codes based upon your model specs. try this first. if this fails, then send the module off to a rebuild company for less than $150.
Old Mar 12, 2014 | 02:02 AM
sf_brian's Avatar
So the mechanic told me that for $900 I get a new module ($700+) w/ a 2 year warranty and replace all my brakes & rotors. I called the closest Audi dealer & their estimate is $1300+ for parts & $700+ for the Labor which is more insane if you ask me.
Old Mar 12, 2014 | 02:06 AM
sf_brian's Avatar
I also read a lot of articles online that the 96-01 A4 & VW Passat have these common issues which Audi never recalled in the first place.
Old Mar 12, 2014 | 08:16 AM
soulstep's Avatar
Why would you pay $900 if you can get it rebuilt for $150? Brake pads and rotors are cheap and very easy to do yourself, or if you really don't like doing it yourself then take it in to a shop for that. You'll save yourself $100s.
Old Mar 12, 2014 | 01:04 PM
Mad Cow's Avatar
Exactly, even if you can't/don't want to do pads and rotors yourself, get it rebuilt for $150 and pay the mechanic for the brake job afterwards. Instead of paying $900 you'll be paying $400 at most, and that's assuming a $250 brake job which is a high estimate.
Old Mar 12, 2014 | 05:25 PM
sf_brian's Avatar
If i have it rebuilt do i need to reprogram? That's my concern here as well.
Old Mar 12, 2014 | 07:06 PM
soulstep's Avatar
I would be extraordinarily surprised if you had to reprogram anything. Even if you did, run the numbers.
$150 for rebuild
$250 (stretching it) for brake job
$100 at most for reprogram (if even needed)
That's $400 less than your mechanic quoted...
stang32
Feb 23, 2014 10:53 AM
hoff5858
Feb 20, 2014 05:51 PM
mangledlftthumb
Oct 8, 2010 08:54 PM
jjuzwik
Dec 10, 2007 12:00 PM
mallett427
Jul 20, 2006 08:10 PM
