2001 A4 clicks only when in gear, clicks in all gears
Old Oct 12, 2012 | 07:57 AM
jonbonesjones's Avatar
Moderator
check your cv joints, wheel bearings, and front suspension.
Old Oct 13, 2012 | 01:49 PM
AudiBrooklyn's Avatar
Cv joints, axle are good. Could be suspension but why would it only click in gear? Ill have the wheel bearing checked though and get back, thanks .
Old Oct 13, 2012 | 04:36 PM
Moderator
because your moving. The suspension isnt goign to click if your not rolling. does it click if your at idle in drive?
Old Oct 13, 2012 | 05:34 PM
It's stick, only clicks when in gear, if I'm off the gas but its still in gear it will click. If I push in the clutch and its neutral it won't do anything even while moving.
Old Oct 13, 2012 | 05:55 PM
Moderator
tranny or clutch problem. Do you have a lightweight flywheel?
Old Oct 13, 2012 | 07:17 PM
Wow that sounds really expensive. No it's a stock flywheel.
Tranny though? It drives totally fine, it sounds like something is loose and flapping around almost. Gonna have it taken apart tomorrow.
Old Oct 14, 2012 | 06:27 PM
Ok fixed it. Got the car on a lift and took the wheels off, the boot was torn on the axle, not leaking yet, and the cv joint wasn't broke but was loose and could be shook. I'm assuming the clicking was coming from it being loose. I brought it to a local mechanic I guess he didn't see anything ripped on the joint and figured it was fine (definatley never going back there) I bought a new axle for $100 getting it put in tomorrow.
Oh yeah thanks for the help, I probably wouldn't have double checked the cv joint if you didn't say anything.
bassthrive
B7 Models
Apr 21, 2011 09:18 PM
pullacowonaski
Mar 23, 2011 02:15 PM
johnstef
Nov 3, 2008 03:41 PM
SeaWolfxix
Jun 29, 2006 07:13 PM
Incubus
Apr 7, 2006 06:22 PM
