2001 audi a4 1.8t shaking
Old Aug 10, 2014 | 09:26 AM
a4dreb5's Avatar
Originally Posted by A4TurboGuy
NP
Your car is the same as mine ('01 1.8t) and I've done my fuel filter. It's really easy. It sits under the drivers door and when you look at it, you'll know exactly what you need to do. If not ask for help and I'll walk you through it.
With Seafoam, use "Seafoam" (that's the product's name). Read the directions well.
After that, buy some "Lucas upper cylinder lube" and follow the directions on that as well.
G/L w/everything.
Hey quick tips with the seafoam? I read the instructions and still not completely sure what to do or where to put it
Old Aug 11, 2014 | 10:52 AM
A4TurboGuy's Avatar
Pour 1/3 of the can into the gas tank, another 1/3 into the oil crankcase (where you would normally fill your oil) and the other 1/3 into the vacuum system (while the car is running). Just disconnect whichever vacuum line you want (I used the brake booster line the first time I did mine).
Once the engine has sucked up the last 1/3rd, turn the car off and let it sit for 5 minutes. After that, fire it up and watch the smoke show
Also: Disregard my Lucas recommendation. Just find your favorite one time "Complete" fuel system cleaner (after you R&R the fuel filter) and dump that into your tank.
After that, you should be good.
Old Aug 11, 2014 | 02:26 PM
a4dreb5's Avatar
Thanks for all the help.. Did everything last night and immediately it stopped shaking however today it's shaking again I'm not sure what it is at this point
Old Aug 12, 2014 | 01:41 PM
A4TurboGuy's Avatar
NP.
Is it shaking while idling?
Old Aug 12, 2014 | 07:26 PM
a4dreb5's Avatar
NP.
Yes that's when it shakes. It shakes now just when I start it, but as soon as I get it on the road the next time I stop at a light or something
Old Aug 13, 2014 | 09:36 AM
A4TurboGuy's Avatar
Well: It's either a fuel, air, spark, or cat issue (this includes any associated electrical circuits).
Try checking your air filter and ducting.
Old Aug 13, 2014 | 01:40 PM
mtroxel's Avatar
I think you need to go back to Devil's comment:
The flashing CEL means you're actively misfiring
You need to VAG-COM that pig and find out which cylinder(s) is(are) missing. If it's just one cylinder, you can start switching plugs, injectors, coil-packs to see if the miss follows. And, if it's just one cylinder consistently, you can forget all the sea-foam/fuel filter stuff. That affects all 4 at the same time.
You need more data. If you have to pay someone to VAG-COM it, so be it. Throwing parts at a car isn't cheap. At all.
Old Aug 13, 2014 | 10:42 PM
  #18
Cybersombosis's Avatar
Just throwing this out there but do bad motor mounts or trans mounts cause this?
Doug
Old Aug 14, 2014 | 05:43 AM
  #19
ImTheDevil's Avatar
Mounts can cause it too but with a flashing CEL the engine needs a closer look. At least stop at Advance and have them scan the car for codes. A generic code reader will tell you your misfiring cylinder(s) but you'll have to keep going back every time you alter something to have it rescanned and they aren't allowed to clear codes. Ask around work/school if someone has a code reader they can loan you so you can narrow it down at home. Meanwhile, download Vagcom and order a USB-to-OBD2 cable for $25 on eBay so you'll be able to get more intimate with the car's issues in the future.
agagne7
Feb 20, 2015 01:35 AM
martinaudi123
Jul 18, 2014 03:12 PM
Reptarr
Nov 24, 2013 08:10 PM
sharabm
B7 Models
Sep 21, 2013 01:16 PM
uzi1314
Jan 4, 2009 03:00 PM
