4.2 Swap
Old Nov 14, 2009 | 10:05 PM
amp832's Avatar
Member
Default 4.2 Swap
so I have a 1996 A4 2.8. I am wondering about swapping the engine out. I have thought about putting in a 4.2 V8. How much work is it to do a swap? What is everyones opinions?
My cars body is in great shape and its exactly what i want. but the engine has 211k and id like something a little faster.
Old Nov 14, 2009 | 10:21 PM
hiwords's Avatar
you need a 4.2 that's DBC. then you need to mod the harness, engine mount, and radiator support. you might need to mod the gasket between the engine and tranny to fit the starter. also the swap is much easier if you have a manual, that way an S4 clutch would work
Old Nov 14, 2009 | 10:40 PM
amp832's Avatar
Member
would it prolly just be best to sell it and get a different one?
Old Nov 14, 2009 | 11:04 PM
Andrew149's Avatar
duh!!!!
Old Nov 14, 2009 | 11:59 PM
kriptonik's Avatar
Sell it and get an Evo.
Old Nov 15, 2009 | 10:41 AM
The Russian's Avatar
Hey! I take offense to that...
But back to the original topic to help you out a bit:
1. the cost is quite high (but worth it in my opinion)
2. this is a fully custom build, so there are no step by step instructions... you just have to do whatever it takes to make it work
3. I did 4 months of research or more before i started... so you should do the same just so you know everything inside out. otherwise you might end up with a pile of metal that just sits there
Old Nov 15, 2009 | 01:03 PM
amp832's Avatar
Member
thanks for the advice...
and no i will not buy a evo..
o0hmikee
Oct 24, 2011 10:19 PM
HulkB5
Aug 8, 2011 09:21 PM
vtraudt
Jun 26, 2011 11:22 PM
impaler2383
May 17, 2006 11:29 PM
dtownhotcorner
Mar 18, 2006 07:20 AM
