97 1.8t starter wiring question
Old Feb 11, 2016 | 06:51 PM
91westy's Avatar
Default 97 1.8t starter wiring question
I recently had a no start problem that I'm trying to diagnose. After replacing the starter and ignition switch I'm still not getting anything. So I pulled the starter again and had the local FLAPS test it on the way to work this morning. According to their diagram, when the guy put power to the spade terminal on the upper left as seen in image 10 here as his computer tells him to do:
Audi A4 1.8T Volkswagen Starter Replacement | Golf, Jetta, Passat & Beetle | Pelican Parts DIY Maintenance Article
(my starter has 2 spade connectors) there is nothing. If he puts power to the other spade connector the motor spins. I'm 99% sure it was hooked up to the one in the pic when I took it the old starter off.
So, which one should it be hooked up to? Will it hurt it to hook up to the other side if I can even get it on the connector?
vtraudt
Oct 10, 2013 01:33 PM
beat180
Jun 20, 2011 04:16 PM
tmanley
Aug 26, 2009 10:58 PM
Mya4T
Oct 23, 2007 06:15 PM
enginerd
Feb 23, 2007 04:05 PM
