97 A4 quattro 2.8 runs hot at idle and down interstate
#33
coolant leak is another problem...there should be like 2-3 phillips screws holding in your coolant reservoir...take those out, and see if you can find a leak, might just be a bad connection....sorry, don't remember everything we were talking about...a leak, you will have to find on your own, I can't see what you're looking at...the sensor should fix your gauge giving you a misreading tho...
#36
first post, and wanted to share my same issue.... I bought a 97 a6 quattro 2.8 12v with bad head gaskets.... it would boil the coolant in the motor after some driving, but the gauge would never go past 1/2, but the coolant warning symbol on the cluster would come on.... I fixed the heads, but after I was done I had the same thing goin on as U do, and I found that my system wasnt bled out properly.... heres what I did that worked like a charm...
open the bleed skrew on coolant pipe that connects the heads together, (drivers side of pipe behind the head) fill cooling system till no bubbles come out... I then took a pressure tester and pressurized the system, and loosend the top most clamp on the heater core and waited till it was only coolant coming out. I was amazed @ how much air the system holds, in my 13 years of working on cars for a living I havent seen a car hold so much air after U open up the system (I honestly avoided audis because of how picky they are, and now I own one =) ) if U dont get ALL the air out, it will boil the coolant out of the expansion tank when U shut the car off...
firechickenmatt
01-24-2015 03:13 PM
socal_A4
05-26-2007 02:07 PM
