A4 having problem with oil in the coolant
Old Oct 3, 2010 | 06:47 PM
skipperben2's Avatar
Default A4 having problem with oil in the coolant
i am having a problem with oil going in my radiator system. if the resevoir gets low then the oil get in the coolant and lands in the resevoir. then this week it turned into something that looked like a frosty malt...the result is the engine over heating.. can anyone tell me where this oil comes from and why... I hope for the best..
Old Oct 3, 2010 | 08:27 PM
bkraska's Avatar
We would have a better idea if you posted the year and engine type of you Audi. But from what you are describing, it sounds like it may be the oil cooler. It is located right above your oil filter. When it goes bad, oil and coolant mix and it sounds like you are losing coolant also? If so , how does your oil level look?
Old Oct 3, 2010 | 08:31 PM
Mike-2ptzero's Avatar
Most of the time it is the oil cooler(exchanger) that cracks and the oil/coolant mix.
Have you checked to see what the oil looks like?
Old Oct 3, 2010 | 09:25 PM
It's a 98 A4 2.8
Old Oct 3, 2010 | 10:24 PM
Default oil in coolant
Audi is an a4 2.8
Old Oct 3, 2010 | 10:39 PM
joenelson7687's Avatar
how hard are those to change out?
Old Oct 4, 2010 | 09:04 PM
bkraska's Avatar
From AudiDIY.com
Step 2 Remove existing oil cooler
Remove existing oil cooler and coolant lines.
Remove the jam nut (8) from the threaded tube (5) that goes through the middle of the oil cooler (7). Then unscrew the threaded tube (5) for oil cooler. Use a vice grips or similar tool to unscrew the threaded tube. You can cut and reuse the original tube if you don't damage it. If you plan to cut it and reuse it, use care to not damage the threads when removing. Wrap threads with a towel or similar item to protect.
Remove the feed line and return hoses from the oil cooler. Using pliers, squeeze the clamps and slide them up and off the oil cooler. Then pull off both hoses. You will re-use the hose 058 121 058 A that goes from the throttle valve housing to the oil cooler. To be safe, you can purchase a new hose, although mine looked to be in good condition so I just reused it.
The oil cooler should basically fall off at this point.
Old Nov 25, 2016 | 04:42 AM
sandeepmahindra's Avatar
Default Coolant and engine oil mix - milky
Audi A4 2008 - GCC specifications
Audi A4 Chasis Number/VIN - waujc68k88a024389
Coolant and engine oil mix - milky this comment is in just addition to the forum thread.
R
Sandeep
+971523261715
Old Nov 27, 2016 | 04:58 AM
Johnnyboy808's Avatar
Before changing out the oil cooler, go ahead and do a compression test; what you're describing is textbook head gasket. Do you get white smoke out of the exhaust? Do you run low on coolant? A compression test will tell you right off the bat, is simple to do, quick and inexpensive.
Zipper
Aug 2, 2009 03:51 PM
michaelh305
Jun 12, 2008 05:27 PM
pv1127
Jul 24, 2007 05:34 PM
solrac
Jul 16, 2007 08:55 PM
Logik250
Oct 2, 2006 10:15 PM
