99 2.8 quattro with issues
Old May 13, 2013 | 04:14 PM
bostonspgs's Avatar
Default 99 2.8 quattro with issues
Hey guys , new here lookin for advice . I went autozone to get my codes read . They could make a connection to the ecu . I have had the car for 2 weeks , and it is killing me on gas . Ive put on just over 600 miles on her and taken 280 to keep gas in the tank . Its acting like its in limp mode with a bad tps . Though Audi doesnt use a tps , and mine isnt turbo so there should be no limp mode . My car is not dbw . I did the adaptation with no improvements . Any pointers would be much appreciated .
Old May 14, 2013 | 10:40 AM
redmond1501's Avatar
So... were you able to pull the codes? That's the starting point.
You can get a generic reader at Advance Auto Parts for $40.
Is the car a manual or auto transmission? If auto, you'll know if it's in limp mode because all the gears will be illuminated and you won't be able to get out of first or second gear.
On my 98.5 at least, I've always needed VAG-COM to do a throttle body alignment -- the key method doesn't work.
Old May 14, 2013 | 10:54 AM
GusTaVz_a4's Avatar
whats up boston so when you start your car do you notice all the gears illuminated, i recently had this problem and it ended up being a bad maf, theres a wire i bought from amazon and i used my laptop for the free vcds software check out my old thread below
https://www.audiforums.com/forum/b5-...p-mode-194462/
Old May 14, 2013 | 03:18 PM
If it's the MAF, I have a working Bosch unit for $20 and live in Boston. I've also got a generic ODBII cable and VCDS lite.
The only time I got into limp mode was driving with the MAF unplugged.
Old May 14, 2013 | 08:01 PM
bostonspgs's Avatar
Its a manual and no connection at all . Couldnt pull any codes
mcko1212
Mar 17, 2015 11:08 AM
nickmcc
Jan 16, 2013 11:08 PM
jer1
Sep 26, 2007 09:57 PM
OhTwoQuattro
Jan 22, 2007 07:17 PM
jhawk1977
Apr 11, 2006 03:02 PM
