A4 1.6 a/c compressor won't engage
Old May 18, 2010 | 07:53 PM
smilingrick's Avatar
Default A4 1.6 a/c compressor won't engage
Need some help here please........a/c compressor won't energize when i turn on the a/c....works fine if i run a direct 12v line to it.....there is voltage in the wire until i put load on it, it just falls to zero. Any ideas?
Old May 18, 2010 | 11:10 PM
auditech79's Avatar
We have fault codes for a reason. If the ECON button stays lit in the a/c control head there is a fault code stored.
Old May 18, 2010 | 11:57 PM
CentauriA6's Avatar
Member
check the pressure switch for 12v located to left side of condenser. check top two terminals, that was my problem follow to wires to the connections beneath the PS fluid resivwar. theres 4 prongs top two for compressor bottom two for elec fan. if theres voltage cross top two terminals, if the compressor clutch engages the pressure switch needs replaced and new refigerant added. the switch shouldnt be more than 30 bucks
Old May 19, 2010 | 05:51 AM
Thanks Centauri......i'll check it today and let you know....
Old May 19, 2010 | 02:25 PM
CentauriA6's Avatar
Member
cool let me know, and btw the car needs to be running for the test to work
and is your econ light on???
Old May 20, 2010 | 12:53 AM
CentauriA6's Avatar
Member
any success smilingrick?
Old May 20, 2010 | 06:30 AM
Default Success
worked all night and checked and checked...eventually i found the a/c relay was faulty so i changed it and Presto.....good as new...Thanks for your help.
Old May 20, 2010 | 12:16 PM
CentauriA6's Avatar
Member
No problem, I had the same type of issues w/ mine. Worked day and night to figure what was going on. theres nothing worse than having a car w/ leather in the summer w/ no AC. The relay would have been my next guess. good job!
Bill Stramm
Sep 25, 2011 02:39 PM
harryb5a4
May 12, 2011 11:55 AM
q5newbie
Oct 24, 2010 11:30 PM
Joshlawrence83
Aug 14, 2010 11:57 PM
gman
Sep 11, 2004 12:36 PM
