A4 b5 2.4 v6 not starting
Old Aug 9, 2013 | 01:37 PM
darrylww's Avatar
Default A4 b5 2.4 v6 not starting
Hi, i recently changed my water pump on my b5 2.4 v6. after the job was completed I started the car and let it warm up. I then switched it off and restarted a few times. no problem. the next morning I started the car and started to reverse when the car stalled and now will not start. It seem to be flooded. I now swings but sounds as if the ignition timing is right out. (poping coming from exhaust) I have checked for spark which is good and the injectors are delivering fuel. I even check to see if the valve timing has moved, I removed the tappet cover and checked that both banks marks line up on the camshaft chain marks and notches on the sprocket with the crankshaft on the mark. it seems as the "ignition timing is out. what could cause this. Please help
makhack
Jun 23, 2011 12:42 PM
Audcura
Mar 9, 2010 11:48 PM
jojoenglish85
Feb 2, 2009 03:30 PM
Honda882000
Dec 27, 2007 10:37 PM
doubleDee
Sep 18, 2007 07:27 AM
