Coolant Problem.. HELP!!
Old Aug 2, 2009 | 03:51 PM
Zipper's Avatar
Exclamation Coolant Problem.. HELP!!
So, it all started when I got a CEL for the Coolant Temp Sensor. So I changed it with a new green version. The light went away, but apparently I did something stupid with the sensor clip as it was not tightened properly. So when I took it out for a drive, the coolant started leaking.. vapor.. smoke etc.. Had to take everything apart and make sure the sensor was put in right. I then filled up the expansion tank with more coolant/distilled water until the max line and took it for a ride again.. The temp gauge was hitting high and once again the coolant in the expansion tank had dissapeared. I check for leaks, but couldn't find any.. no vapor, no smoke.. just the engine heating up and the coolant gone! Could it be that it needs more coolant?
I should mention that I also put in a RAM intake when I put the temp. sensor. I VAG'd the engine blocks 02/03 for the injectors/MAF etc and they all look fine, within the range.
Has anyone got any idea what's going on? I'll probably go get some more coolant tomorrow.
Boost Apostle
Aug 5, 2009 04:01 PM
michaelh305
Jun 12, 2008 05:27 PM
pv1127
Jul 24, 2007 05:34 PM
solrac
Jul 16, 2007 08:55 PM
Logik250
Oct 2, 2006 10:15 PM
