Aftermarket Head unit install problems
I don't mean to add confusion to this situation, but I did run across this post when I was looking into upgrade possibilities with the Metra harness. This is from a guy who purchased the harness at Amazon.com:
"I purchased this item for my 2000 audi A6 with bose stereo so i could install a pioneer head unit. when installed as directed, the speakers all emitted a high pitched alternator whine whether i was listening to the stereo or a cd. i knew the HU worked properly, and so did the factory stereo, so i checked the harness for possible fixes. i found no unwanted noises came through the speaker when, instead of hooking the rca adapters (on the harness) up to the preamp outputs (on the HU), i hooked the speaker level outputs (on the stereo) to the rca adapters (on the harness). so to fix the problem, i cut the RCA adapters off the harness, and soldered those wires directly to the speaker level outputs from the HU. now everything works and sounds great."
I don't know if this will help, but thought it might because the wiring on the harness was not as expected.
jdahlen, i think that "could" work but i have a feeling not as well as it could.
the bose system wires up opposite the non-bose.
meaning u use the front RCAs not the back but u DONT wire the front wires, u wire the back.
in my case i dont wire the back just the front.
Ok so reading through the manual on page 52 and 53 this is what I've found as I've suggested before.
I don't know if this will solve it or not but what you can do is also test the RCAs on the kit harness with the front RCAs from your head unit instead of your rears due to the above excerpt and connect them to the purple and green RCA's going into the Metra harness to see if you get sound. Let us know how it goes.
Doug
Doug
its not detecting anything, thus not allowing me to change the "rear speaker" setting. all i can do is turn "subwoofer" on and off but it has no real effect right now.
so ur suggesting un-wire the front speaker wires from the h/u and plug in the front speaker RCAs instead?(into the rear speaker RCA output on the h/u?) thus proving theres nothing wrong with the RCA output on the h/u?
or wire the front speakers to the rear speaker RCAs(being as they aren't amplified) to make sure the metra RCA harness works correctly, proving that it HAS to be something wrong with the amp not getting the right signal/juice?
At this point you can even take a 1/8" jack to RCA and plug them into the wiring harness, turn on your head unit to trigger the amp on, then plug the 1/8" jack into your ipod/phone and play something to see if you get sound thus eliminating the amp out of the equation.
Doug
yes i can use the front RCAs, i get what ur saying now.
and when i get to work tomorrow ill grab the jack/RCA converter(idk why we have one there but i know i do.
as for the subwoofer output, Ive played with that option, it has no effect.
just had a thought, if you look at this picture
"line out"(circled in red)
pins(numbered for simplification)
1 2
3 4
5 6
(1, 2, 5 ,6 = speakers. 3 = remote on. 4= com.)
number 4 is labeled as "com."
being a black wire(which always means ground) shouldn't that be labeled as "ground" idk what "com." means. what are the chances that this could be my issue? its wired into all 4 RCAs with all black wire, cuz im almost certain my speakers are on, but no sound. could that not be grounding but maybe is suppose to???
[just to reinforce my thought process if you look, ground is labeled elsewhere on this diagram as "gnd"(as it should)]
1 2
3 4
5 6
