Aftermarket Tail Lights Question
Old Dec 3, 2011 | 03:59 PM
mstig542's Avatar
Default Aftermarket Tail Lights Question
Hi I've had my 2000 1.8t for a little over a year now and i love it so i decided to start modifying it. The only problem i've had thus far is when i put in my aftermarket lights. the headlights went in fine but the tail lights came up with a brake light out symbol and an annoying beeping sound every time i hit my break peddle. i know that this is happening because the new light assembly does not use the old plate(where all the bulbs were attached) because they are LED lights now. So my question to you guys is... is there some sort of chip or unit that i can buy that will over-ride the current error code or am i going to have to make a bypass circuit(if so how?). Thanks everyone, im so glad to finally be a part of this forum.
Old Dec 3, 2011 | 05:55 PM
ImTheDevil's Avatar
You could measure across the bulbs that were in the tails and then install a load resistor in the LED setup so that the combination of the LEDs and resistor has the same impedance as the bulb. That's the quickest way to fool the car since it likely uses a voltage sense to determine if the bulbs are lit or not.
Old Dec 4, 2011 | 08:38 AM
mstig542's Avatar
OK i'll give that a try thanks.
Old Dec 5, 2011 | 08:48 AM
CCA4's Avatar
a member here called Emil sells resistors for this purpose. PM emilgevor for more info.
FishEye
Mar 25, 2012 03:13 PM
rimvydazas
Oct 1, 2009 07:08 PM
Chechen_Rebel
Jul 11, 2009 12:11 AM
90sMoneypit
Mar 21, 2008 01:04 AM
vdub_15
Aug 20, 2006 03:03 AM
