Auto transmission removal
Old Aug 24, 2012 | 09:15 AM
mrk3cobra's Avatar
Do I need to remove the front end to get the starter out???
Old Aug 24, 2012 | 09:18 AM
mtroxel's Avatar
What motor do you have? If it's the 2.8 you need to put the front in service position. It's only a 15 minute job. But on the 2.8 you have to remove the alt, then the starter. And it's hard enough with the front moved out.
Old Aug 24, 2012 | 09:27 AM
mrk3cobra's Avatar
The motor is a 1.8l.. What does put the "front in service position" mean.
Does the exhaust need to be dropped from the turbo back?
Old Aug 24, 2012 | 09:32 AM
mtroxel's Avatar
If you're going to do this, you need a Bentley. "Service postion" is when you pull the front forward about 6 inches. B5's are made to do this without disconnecting coolant hoses and AC lines.
Old Aug 25, 2012 | 03:35 PM
mrk3cobra's Avatar
Almost done removing the old transmission in my 1.8l having trouble removing the catalytic converter it will not drop out the bottom of the car and will not fit out the top.What is the solution, the manual does not address this.
Old Aug 26, 2012 | 09:57 PM
mrk3cobra's Avatar
Transmission out of car. I found that I had to separate the cat from the downpipe to remove the cat, just not enough room to get The cat and downpipe out together.
Would you rebuild a damaged auto transmission or buy a used low mileage trasmission on eBay?
Old Aug 26, 2012 | 10:03 PM
mtroxel's Avatar
All I know is....I had a shop rebuild mine. Put it back in. It lasted 1 month. Shop rebuilt again. Lasted 2 days. Shop rebuilt again, this time it lasted but it always made noise. It was never right.
Old Nov 21, 2021 | 05:59 AM
  #18
fuhrer's Avatar
hello : " you have to remove the alt " , may you tell me what is ALT please?
Old Nov 21, 2021 | 09:32 AM
  #19
mtroxel's Avatar
alt = alternator
Old Nov 21, 2021 | 03:47 PM
  #20
fuhrer's Avatar
Originally Posted by mtroxel
alt = alternator
thanks a lot
Audia4turbo323
Dec 4, 2013 01:27 PM
PacificA4
Jun 18, 2012 08:36 AM
Ron Sweeney
Jun 12, 2011 04:10 PM
audijosh
Dec 4, 2007 03:20 PM
joshuo
Jul 2, 2007 09:21 PM
