Battery brand recommendations?
Old Dec 22, 2010 | 05:45 PM
Boober's Avatar
Default Battery brand recommendations?
My battery's dead for the second time, its a die hard... anybody have good experiences with other brands?
Old Dec 22, 2010 | 06:24 PM
jdahlen24's Avatar
I've used nothing but Interstate batteries for my car. I'm on my second one, the first having lasted six solid years. The only reason I replaced it is for preventative maintenance.
Old Dec 22, 2010 | 06:29 PM
FASTER's Avatar
Tech Slut
They are mostly the same thing with a different sticker. Do yourself a favor and don't buy the recommended one for your car. It'll run you almost 200 bucks iirc. I got one that's almost the exact size and the same cold cranking amps that was recommended for a Lexus SC300 I believe, which cost like 75 bucks.
Old Dec 22, 2010 | 10:54 PM
dragonrage's Avatar
Go by warranty.
Old Dec 23, 2010 | 01:25 PM
bradtyler02's Avatar
Duralast Gold from AutoZone is what I got. Set me back a buck fifty, 3 year replacement, 7 year prorated warranty. Haven't had a problem since...
(I'm not saying that's what you should get, that's just what I got)
Old Dec 23, 2010 | 02:52 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
I'm due for a new battery as well.
Old Dec 24, 2010 | 10:51 PM
caffel's Avatar
Default Some AUDIs run the battery hot
meaning they keep the voltage above average even when fully charged.
If you live in a hot climate that makes it worse.
If your model has high temps under the hood ....
Check the voltage when running with an accurate voltmeter.
beefski
Sep 8, 2008 10:02 AM
floepie
Dec 4, 2007 04:04 PM
BFlan2001
Jan 15, 2006 11:17 PM
