Bleeding Brake fluid...and then some...
Old Feb 2, 2009 | 08:51 AM
dhavi4226's Avatar
If your reservoir is cracked you WILL NOT be able to pressurize the system. You have to change it before you proceed.
While it's said that there are no stupid questions, sometimes it makes a person wonder if the one asking it should really be working on a system as CRITICAL as brakes. Perhaps you should seek out a good repair facility.
Old Feb 3, 2009 | 11:44 PM
lleroyb's Avatar
Member
If your reservoir is cracked you won't be able to maintain pressure to bleed with. I just did this on a Boxster and I think the reservoir is the same part as on my daughter's A4. I had no problems at 15 psi on the Boxster, or any other car for that matter. If you are hesitant you could try 8-10 psi, it will just take longer.
Lou
esrest
Jan 20, 2013 10:17 PM
makav3li
Apr 18, 2010 10:52 AM
Lsand
Aug 2, 2007 12:29 PM
moeron7
Apr 6, 2007 07:53 PM
AudiS4_190
Feb 12, 2007 09:50 PM
