Boost Surging
Old Jul 24, 2011 | 02:25 PM
supergoober752's Avatar
Default Boost Surging
Hey guys,
I have a 2001 audi a4 1.8t APR chipped R1 DV. Been happening since the beginning of summer. Ill hit the gas, boost (boost gauge shows 15psi steady) but the boost/power cuts in and out. Virtually, when i boost im loosing RPMs and the power will cut in and out.
Really weird, any ideas?
Thanks
Old Jul 24, 2011 | 04:54 PM
CCA4's Avatar
What's your intake look like? Stock? Cone filter? Any codes/CEL?
Old Jul 24, 2011 | 08:49 PM
airguard350's Avatar
Tech Guru
What do your vacuum lines look like?
Old Jul 25, 2011 | 04:13 AM
replaced all my vacuum lines when i installed the boost gauge, they were really corroded.
Intake is stock. replaced the filter a couple times looks good. Did not plug a vagcom in yet, didnt think it would shoot a code for this, but ill head to my local store tomorrow and do so anyway.
Think a diode might fix this? could be in limp mode but im not sure it would be if the turbo is surging..
Old Jul 25, 2011 | 12:25 PM
CCA4's Avatar
if you were in limp mode you'd be seeing a CEL, and about 4lbs of boost at the most. You might be hitting some kind of soft limp that just cuts boost without the CEL? I have a spare diode sitting around, if you want it just PM me your address and I'll drop it in the mail.
thesupremeg33k
Apr 2, 2015 02:46 PM
xxNeverG1veUpxx
Oct 15, 2013 10:37 AM
audi_lade
Oct 9, 2012 05:10 PM
new2me
Nov 26, 2007 01:22 PM
burnt_toast
Oct 13, 2007 08:05 PM
