broke a bolt, now what? *pics*
Old 09-07-2011, 10:57 AM
strokestroke's Avatar
Just get a thin cut-off disk on an angle grinder and carefully cut the bolt out, in between the pinch-point space. Then heat,hammer and punch the remaining bit out or use an extract-all bit.
Old 09-07-2011, 01:22 PM
airguard350's Avatar
Tech Guru
Yeah, bshusted, but since it's a nut/bolt combination thread pitch in this instance doesn't really matter as long as the new nut and bolt have the same pitch. I've done this the way I've described and it worked perfectly for me.
Old 09-07-2011, 06:17 PM
Horner's Avatar
Use a torch and some freezing fastener remover from autozone or whatever.
Heat up it up and hit it with the spray. then heat it up again anf hit it with an air hammer and it should just about fall out. A cheap air hammer might run you like 40 bucks or so from lowes, sears, harbor freight, etc. Make sure you buy a tapered punch for your air hammer to get access to hit the bolt itself. If you lived on the east coast i could do it for you in no time.
Remember its only metal so DONT be nice to it or you will be there all day.
Good luck with your new found project
Old 10-17-2011, 09:55 AM
taz2ko0's Avatar
Originally Posted by bshusted
Let it soak in penetrating oil and see if you can punch it out. Can you spin it with the other end? You may need to warm it up with a MAPP gas torch and then douse it with water to break the corrosion.
I know it's no consolation now, but I was able to get my cv's out without undoing any of the suspension. Once you get the big hub bolt out, put the chassis back on jackstands and then remove the top bolt for the transmission on the side you're working jacking the transmission about an inch gave me plenty of room to slide the outer spline out of the hub.
Where is the bolt located. I need to do same thing on both sides.
Old 10-17-2011, 12:09 PM
ImTheDevil's Avatar
The only bolts that have to come out are the end axle bolt and the six 12-pt diff-axle bolts. That's it. No pinch bolts need to be removed. No tranny bolts need to come out. Seven axle-related bolts, some swearing, and it's out. That's all.
Old 10-17-2011, 03:40 PM
bshusted's Avatar
I found that when removing the CV shaft, the shaft itself was long enough that there was no way I could get the shaft out. The transmission bolt I removed was the bolt that goes into the top of the transmission mount from the big aluminum bracket. Then I used the jack the transmission to lift it an inch or so. This gave me just enough room to remove the shaft from the cup part of the diff.
Perhaps you won't have this issue when doing yours. I would proceed as the Devil suggested, but if you run into the same issue just pull that one bolt and lift the transmission a bit. to gain some more room.
Old 10-18-2011, 07:59 AM
taz2ko0's Avatar
Thanks, guys i am buying the cv joints. I am buying the ones from FCP Groton, unless you guys have any better suggestions. BTW this car is my winter beater, no racing or hard driving. (v6 quattro 99)
  #18
Old 10-18-2011, 08:06 PM
AudimaniaA4's Avatar
I think that bolt sldes out from the other side.
  #19
Old 10-21-2011, 10:24 PM
livinglegend2100's Avatar
Thumbs up
^what he said. with a little more swearing on top. I did mine a couple weeks ago (2001 2.8 quattro) with the front end of the car on jack stands, i used a floor jack to lift the knuckle up out of the way and it came out with some finaggeling. and that was just for the passenger side. the drivers side basically fell out once i unbolted it...
iwbafam
06-09-2011 10:15 AM
Fall0ut
01-11-2011 04:34 PM
freeride599
01-26-2010 01:29 AM
DavidDean
06-08-2007 02:53 PM
a4r6
05-20-2006 07:03 AM
Quick Reply: broke a bolt, now what? *pics*
