Call me crazy... (wipers)
Old Mar 6, 2008 | 12:32 AM
duburban's Avatar
Default Call me crazy... (wipers)
So i replaced the wiper motor... cool for a little while but the wiper tranny is just to stripped to lock on for good now. So i'm wondering why not just weld the two together. I don't know sh#t about welding, but if i could weld these metals together i see no reason not too. Just to clarify, i'm talking about the connection between the wiper motor and wiper tranny. This is usually friction held by some small grooves and the nut on top. Some might say, don't weld it cause you'd have to put them in and take them out in one piece but by removing the ecu thats no problem. Seems like a permanent fix to a trouble spot. Ideas?
Old Mar 6, 2008 | 12:37 AM
01AudiA4's Avatar
Default RE: Call me crazy... (wipers)
Hmmm I didn't really know the wipes had a tranny?
Are you just talking about the gears that move them?---You could always weld it but bad idea becuase when you weld spot welds goo all over the place
SO DONT DO IT!
Old Mar 6, 2008 | 12:44 AM
duburban's Avatar
The system that connect the wiper motor to the wipers is called the wiper tranny. It would be welded outside of the car and put back in. I don't know where you live but up in new england i see Audis with the wipers stuck halfway up all the time.
Old Mar 6, 2008 | 01:55 AM
qUaTtRoA4's Avatar
take a pic of what you think you are gunna weld, i can't get the image straight in my head
I am thinking you are talking about the joint, but I may be wrong, sounds like you may be able to drill/bolt/reinforce w a plate
just take a pic, and maybe use a photochopper to circle the spot you want to weld
Old Mar 6, 2008 | 08:27 AM
01AudiA4's Avatar
No i think he means where the grooves are that holds the actual Wiper-the metal part in there, Then the bolt screws on top. Those Grooves are stripped and the wiper doesnt catch.
Correct?
Old Mar 6, 2008 | 04:09 PM
duburban's Avatar
ORIGINAL: 01AudiA4
Correct?
Yes Correct. Seems like if you catch the wipers while there working with a spot welder you might save some long term hassle. This is really only a concern for people in snow belts. I'm not actually going to weld it but i'll be using a punch to create new friction and some loctite to help hold. Why not replace? It costs more for the same function.
Old Mar 6, 2008 | 09:22 PM
The Bishop's Avatar
JBweld would be alot easier.
Old Mar 7, 2008 | 12:01 AM
duburban's Avatar
Right, jb weld, loctite, spot weld...
driventodespair
Mar 24, 2013 09:07 AM
rplets15
Dec 7, 2008 01:19 PM
hunTTsvegas
Aug 14, 2008 06:54 AM
jasmix
Feb 25, 2008 06:07 PM
ttlpjh
Aug 10, 2007 06:01 PM
