cam tensioner special tool
Old Mar 28, 2013 | 10:21 AM
hartsoe1's Avatar
Default cam tensioner special tool
Hey, what is the bolt pattern and size of that special tool. I'm getting ready to do my valve cover and cam tens gasket and I'm not gonna pay $40 for that tool. Thanks
2000 1.8 atw
Old Mar 28, 2013 | 11:41 AM
MrSnickelsnizer's Avatar
Old Mar 28, 2013 | 11:58 AM
phatjames167's Avatar
i got mine off ebay for $12.99
Old Mar 28, 2013 | 07:29 PM
hartsoe1's Avatar
I was hoping I just screwed a bolt down into the threaded hole and it somehow released pressure on the tensioner so I could lift the tensioner just enough to change the gasket underneath. Or, do I need that plastic piece to provide leverage under the chain to get some room to work under the tensioner? I don't understand the mechanics of just getting room to change the gasket, vs changing the entire tensioner, which I'm not going to do. Explanation, please. Thanks
Old Mar 28, 2013 | 10:18 PM
Mad Cow's Avatar
You have to compress the tensioner to move it out of the way and change the gasket. The tool threads into that threaded hole and pushes against tensioner pad to compress it.
Old Mar 29, 2013 | 09:33 AM
just to elaborate, the part of the tool that is pressing against the tensioner pad is the big plastic part. not the bolt part. that's why you can't just screw tyhe bolt down and release pressure. the threaded hole is just a guide and somewhere to hold the bolt while the plastic end holds down the tensioner pad.
I followed this guide when i took care of mine.
How-to: 1.8T Cam Chain Tensioner Gasket replacement
Old Mar 29, 2013 | 04:32 PM
The tool compresses both top and bottom pads, as seen in photo. Just an extra cam tensioner I had lying around. It is compressed fully as you can see.
Old Mar 29, 2013 | 11:46 PM
hartsoe1's Avatar
Thanks all. I just ordered one from Hong Kong.
bshusted
Jul 31, 2013 08:46 PM
asmir02
Nov 5, 2010 11:22 AM
jaymac
Jul 30, 2009 04:08 PM
bottlecap
May 3, 2009 04:27 PM
Prerunnered 1.8t A4
May 25, 2008 10:27 PM
