cam tensioners
Old 11-28-2009, 08:49 AM
cwedholm1's Avatar
Default cam tensioners
Does anyone have a diagram of the cam tensioners. When I start my car up on a cold morning I hear rattling like the cam chains for about 2-3 seconds and then it goes away. I am not sure how the tensioners work, do they work from spring pressure or what. It is a 2001 2.8 with 139,000 on it.
Old 11-28-2009, 11:19 AM
dragonrage's Avatar
They work via magic. You need a whole new one if it's loose. Get it via PureMS.
Old 11-28-2009, 12:04 PM
codymack43's Avatar
Incorrect. They are pressure regulated. I spoke to an audi tech about it. thats why it only happens when the car is idling or cold. It goes away later right?
The only time you would NEED to replace it is if it clicks the entire time youre driving.
It wouldn't hurt to replace it, but why spend the money if its unnecessary?
If youre doing your timing belt you can do it at the same time. but other than that its prob not something you really want to get into.
Old 11-28-2009, 12:12 PM
cwedholm1's Avatar
Correct, it only happens on initial start up. I know my cam tensioner gaskets are leaking but, I was hoping to get through the winter before replacing.
Old 11-28-2009, 12:50 PM
dragonrage's Avatar
Well, just about any part has sort of an intermediate period where you know it's starting to fail but it's not bad enough to need replacement right that second. But don't wait TOO long.
Old 11-28-2009, 05:21 PM
pullacowonaski's Avatar
what does it sound like cause when i start my car up sometimes it sounds like a heat shield rattling for less then a second, but if i turn my car off after a few min and start back up its gone and it doesn't do it all the time either sorry to tread jack
Old 11-28-2009, 07:01 PM
cwedholm1's Avatar
Same thing on mine, it doesn't do it every time.
B5LVR
11-06-2010 09:00 PM
Trey25
08-03-2010 10:19 AM
Ronaldwl1
07-30-2010 04:29 PM
audisaint
05-28-2010 02:39 PM
ukraini9mofo
10-08-2004 01:04 AM
Quick Reply: cam tensioners
