can I change the radio and climate control console?
Old Feb 4, 2010 | 04:17 AM
b5bomber96's Avatar
Default can I change the radio and climate control console?
I have a 96 can I change the climate control, fog lights hazard and radio console set up to like an 99-01 style?
Old Feb 4, 2010 | 05:53 AM
ImTheDevil's Avatar
Yes you can - it's been done quite a few times.
Old Feb 4, 2010 | 07:59 AM
CCA4's Avatar
FWIW, the S4 console is also interchangeable with ours. Search "double-din swap" and see what you get
Old Feb 4, 2010 | 08:34 AM
vgo's Avatar
vgo
Yes you can. Im in the process of gathering the parts needed for this right now. Just waiting for them to be shipped.
You need to find yourself a double DIN cage, and a climate control from 00-01 cars that already had the double DIN cage.
When spring hits, I will ATTEMPT to install this myself and post up a DIY. If not, im just gonna hire a shop to do it for me.
Its gonna require you to remove the whole center console.
Old Feb 4, 2010 | 12:50 PM
b5bomber96's Avatar
Sweet, so everything is just plug and play? If so, I will attempt!
Old Feb 4, 2010 | 01:46 PM
Andrew149's Avatar
plug and play with little modding no big deal
Old Feb 5, 2010 | 08:41 PM
RSX664's Avatar
Old Feb 18, 2010 | 05:40 PM
x2nervisx's Avatar
Well I have a 1999 pre facelift a4 and I just got the center console out of a 2000 a4. When installing the newer console in my a4, I noticed the harnesses in my car for the foglights, rear foglights and harzard switch are completely different to the new style buttons. I have the new style connectors as well and compared them to the wiring on my car. The color codes are almost the same. However the hazard switch has 9 wires on the new style and only 7 on the old style. How do you wire this up? Just leave the other wires not connected?
splauer1us
Jul 6, 2022 09:54 AM
akasjl
B8 Models
May 2, 2014 06:03 AM
brownt46
Mar 31, 2010 12:57 PM
CampbellsChunkySoupr
Mar 23, 2008 09:16 AM
auttiquattro
Aug 11, 2007 10:56 AM
