car not running!!! ignition problem help.
Old Jun 28, 2010 | 07:08 AM
audiquattroa4's Avatar
Member
Default car not running!!! ignition problem help.
got stranded at a gas station, car is blowing black smoke and will not run right, full throttle or idle will not go over 1 grand, with jerking and stalls alot, plugs are pitch black, fauled out plugs, replaced them still nothing, gonna try coil pack today if i can find a pair.
Old Jun 28, 2010 | 08:34 AM
ImTheDevil's Avatar
Definite rich-running situation - could be a boost/vacuum leak causing it. Failing O2 sensors will cause you default to safety fueling maps that will run rich to protect the engine but it shouldn't be as bad as you're describing. You need to scan for codes - running that badly, you're bound to have something logged.
Old Jun 28, 2010 | 04:43 PM
Member
coil packs didnt help, putting it on computer soon
reedo82
Aug 11, 2009 08:53 AM
baz a4
Mar 11, 2008 03:40 PM
BraMas
Apr 2, 2006 12:49 AM
yellowa4
Aug 7, 2005 12:18 AM
bougeac
Sep 4, 2004 04:16 AM
