Car revs high and hunts when battery is disconnected and re-connected
Subscribe
Mar 17, 2010 | 12:09 AM
I have heard that by pumping the accelarator with ignition off can sometimes reset engine....is this true or not? Any suggestions would be much appreciated
Reply
Mar 17, 2010 | 12:13 AM
It's normal - the ECU goes into relearn mode. It cures itself as it figures out what it's doing.
Reply
Mar 17, 2010 | 12:39 AM
is it good for car in general to relearn
Reply
Mar 17, 2010 | 12:49 AM
It's not a bad thing. Leave it disconnected for an hour or so to fully drain the power. Hook it back up, turn the key on (but don't start the engine), and wait for the high-pitched humming to stop (that's the TPS adjusting itself on pre-dbw cars, and the throttle body aligning itself on dbw cars. When it stops, crank it up and hit the road.
Reply
Mar 17, 2010 | 01:07 AM
Thanks for the info, i will try that now and let you know how i get on. Much appreciated.
Reply
Mar 18, 2010 | 12:01 AM
I left the battery disconnected overnight, reconnected it, turned the ignition on and left it a little while. Once i started it it began to rev at about 11/2 again. I turned the engine off, put my foot on the accelerator for about a minute or so started the engine and away it went. All fixed.
Reply
Subscribe
