CEL Codes :(
Old Jan 17, 2013 | 11:15 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Lol, well.
From my Bentley manual:
P0302 - Cyl #2 misfire detected
P0642 - Knock control module malfunction
P0645 - A/C clutch relay control circuit
Old Jan 19, 2013 | 03:11 PM
Dallas09's Avatar
Originally Posted by lukestaah
You guys are useless. I asked a question you don't gotta tell me that I'm getting the wrong codes when I got the codes off my damn machine that reads ABS electronics. Don't try and post on a thread just to get your two-cents in it. NO ONE GOT TIME FOR THAT!
Everyone should stop helping you because youre being an idiot, we don't have over 1,000 posts because we like the mess with people, I can do that while Im sitting outside in the sun instead of in here on the computer... but anyway, you need to be more specific and answer my question.. Did you scan the ABS module or did you scan the engine computer? You said you have a CEL, CEL stands for "Check ENGINE light", do you have a check engine light or do you have an abs light? If you have an ABS light and those are codes from the ABS computer, then your codes do apply to the ABS but you shouldnt have called them CEL's, and hence why everyone is confused. If you have a Check engine light, a "CEL", and you scanned the engine computer then your scanner is giving the wrong description..
Old Jan 21, 2013 | 09:59 AM
McGovs2.7TB5's Avatar
Also you're useless, use the damn search function. These cars have been out since '96, you're not covering anything new with your ******* misfire.
edit start reading: http://lmgtfy.com/?q=Audi+a4+p0642
Old Jan 21, 2013 | 10:29 AM
CCA4's Avatar
Yeah something isn't right there. McGovs and BaseDrifter are correct about the codes, your scanner is reading them improperly. EDL stands for Electronic Differential Lock, which your car doesn't have. When you first plug it in, your scanner should automatically detect the platform, engine code, and ECU code from your car. Can you take a picture of this information and post it up? I have a feeling your scanner thinks your car is a different model and/or year.
No need to get pissy with these guys, they're just trying to help you diagnose the problems you're having.
Old Jan 21, 2013 | 12:53 PM
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
Ruggedboy
Jul 20, 2007 11:30 PM
supercoupe91
Jul 13, 2007 06:20 PM
rafa_207
Jun 27, 2007 01:31 PM
