Central Locking Replacement Pump
Old Apr 5, 2017 | 09:47 AM
Boydcage's Avatar
Default Central Locking Replacement Pump
Hi, I just purchased a 2nd hand vacuum pump for the central locking on my B5. The code on the replacement ends in a letter E (same as my original). The replacement also came with a 3 button key (again, like my original). The problem: I can use central locking with the key that was sent with the replacement pump but I can't sync my original keys to central lock with the replacement pump. Any ideas please?
Old Apr 5, 2017 | 12:57 PM
elduderino200's Avatar
Do you have two keys?
Put one into the ignition, turn to 'on' (i.e. don't start the car - just give it electronic power), then close the door and with the other key, lock and unlock a few times. I believe that's the normal way to sync keys.
Old Apr 5, 2017 | 03:47 PM
Boydcage's Avatar
Thanks very much for your response - much appreciated. The problem is that I have all of the original keys which will work in the door locks and ignition; however, the key that came with the replacement pump will only operate remotely - it won't work in the door or in the ignition so I can't sync in the way you suggested.
Old Apr 5, 2017 | 04:05 PM
Boydcage's Avatar
I have got a bit closer by using your method with my 2 original keys, but it only set one of them up with the remote locking. I swapped them around in the door and ignition and tried again but no joy with the second key. Any ideas would be most welcome please
Old Apr 5, 2017 | 04:26 PM
I forget how to do it exactly but it's something like that.
If you put one known working key in the ignition then close the door and press the unlock/lock a few times with the fob, that might do it? Sorry I don't remember.
It may also be that fob-only 'keys' have to be programmed with VCDS (or at the dealership).
Old Apr 5, 2017 | 04:41 PM
Boydcage's Avatar
Well it's good to have made some progress from your reply; at least I'm back to having one fob on my key ring for now . I'll keep working at it and thanks again for your help .
a3turrell
Jun 4, 2023 11:15 PM
rightsandlefts
Dec 17, 2007 02:45 PM
awakening
Dec 5, 2007 12:55 PM
jrmock
Sep 10, 2006 01:16 AM
radi
Mar 2, 2005 12:47 PM
