clicking noise .....
Old Aug 14, 2009 | 02:16 PM
pullacowonaski's Avatar
Default clicking noise .....
i was driving today and makeing a turn and i heard a sound like a loud clicking noise and i remember when i had it on the lift i saw the cv boot was off on the side that faces the wheel and was wondering if that was it or if it was my tie rod
Old Aug 14, 2009 | 04:25 PM
Midniteoyl's Avatar
Most likely a CV joint. Usually the one on the outside of the turn. If you have one boot torn off, the other is prolly messed up too.
Old Aug 14, 2009 | 06:40 PM
no the boot is not torn it looks like the boot just slipped off
Old Aug 14, 2009 | 06:49 PM
compmanben's Avatar
take a picture of it and post it
Old Aug 14, 2009 | 07:15 PM
Midniteoyl's Avatar
Hmm... However the problem is still that dirt prolly made its way into the joint and wore it out.
Old Aug 14, 2009 | 11:04 PM
Jc61990's Avatar
bad axle? or cv joint? usually one of those cause clicking
Old Aug 15, 2009 | 01:14 AM
A4 2000's Avatar
You should just get a new axle so you can have some fresh cv joints and boots all at once.
Old Aug 15, 2009 | 02:15 AM
Grapeel01's Avatar
Before you go to this trouble and expense, remove the wheel and gently bend back ½" the steel plate cover that extends over your front discs. I had clicking noises from my B5 on tight bends/ roundabouts and the dealer told me this 'trick'.
Old Aug 15, 2009 | 12:07 PM
ok ill try that first and take a pic of the boot
Old Aug 15, 2009 | 04:08 PM
kriptonik's Avatar
The clicking only happens when your steering wheel is fully turned?
If so, I would say it's a bad axle/CV joint like everyone else said.
itsmatt33
Sep 2, 2009 03:17 PM
Herns4
Aug 20, 2008 08:17 PM
a8v8
Jul 3, 2008 12:24 PM
vlado182000
Apr 1, 2007 11:34 PM
jonus079
Feb 19, 2007 09:55 PM
