clutch slippin
Old Apr 23, 2008 | 09:26 PM
fumoazul99's Avatar
Default clutch slippin
my clutch started slippin in 1st,2nd, and 3rd gear... .... How long do you guys think it will last like this? and where can i find a good priced clutch for my car and what am i lookin at for labor?
Thanks guys
Old Apr 23, 2008 | 10:00 PM
hiwords's Avatar
Default RE: clutch slippin
get it from specclutch. if you're not gonna go bt you won't need a light weight flywheel. labor should be like 300 at least.
Old Apr 24, 2008 | 10:15 AM
fumoazul99's Avatar
any more suggestions?
How long do you guys think i could drive it like that untill the clutch burns out completly?
Old Apr 24, 2008 | 10:59 AM
chaos92287's Avatar
the clutch will continue to get worse and worse. mine started slipping under WOT, then would slip under most throttle, then part throttle, and then finally got to where any sort of decent acceleration caused it to slip. The more it slips, the more you'll damage your flywheel, but if you drive it like a grandma, it'll still last for a while. i think mine slipped for a little over a year lol.
for a new one, i would suggest only Southbend. better pedal feel than spec. and if you pm Andrei (slayerrule) over on AZ he'll give you a discount. get stage 1 if you just want a replacement, stage 2 is better for chipped cars and you'll be able to launch it, stage 3 for small to mid sized BT.
Old Apr 24, 2008 | 01:30 PM
fumoazul99's Avatar
chaos... so your saying that i dont even have to get a flywheel if dont damage it?
Old Apr 24, 2008 | 02:30 PM
chaos92287's Avatar
nope, unless upgrading to a lwfw, your stock dmfw should last the life of your car. the more your clutch slips tho the more you'll damage it. but as long as your easy on the acceleration, it shouldn't slip and therefore cause no damage
Matt_Iliketurbopull
May 1, 2007 05:28 PM
Matt_Iliketurbopull
Apr 28, 2007 03:06 PM
